Cab light leaks
RedSmokey
Sacramento, CA
I know its not aftermarket, but there isn't a general 99-11 section so... One of my cab lights are leaking. What should I use to fix it? Hoping to pull the head liner down today and work on it, just don't know what I should use to seal it. And since I'm in there I will probably just re-seal all the cab lights.
Arisley
Arlington, Texas
One of mine was leaking. Went to take off the lens, and one screw was stripped out. Pulled the entire socket off the roof, pecked on the screw hole a bit to reshape it. Replaced the gasket (also put a thin skin of silicone on both sides of it). Problem solved.
