Cam sensor?
Jessy7.3
Utah.
I started my truck just fine and as soon as I would press on the pedal it would go almost like it had a lope tune. Hardly wanted to idle. As soon as I would let off the throttle, it would go back to idling normal. I have a video that I'll post later
Jessy7.3
Utah.
P1670
P0603
P0344
Injector duty cycle: 10.6%
Injector control pressure: 450:500 psi
Map frequency: 0 HZ
map: 11.6 psi
Manifold air temp: 124f
Engine net torque: 11ft pounds
Jessy7.3
Utah.
The trucks rpm drops severely when this miss occurres. I'm starting to wonder if it's an idm
Jessy7.3
Utah.
Found out, I replaced the cam sensor only to have the same problem. I hooked up a scanner and cleared the codes. It passed a buzz test and everything. I messed with the cam sensor and it started working just fine. So I'm gonna replace to pigtail, clear the codes one more time and see if that fixes it for good
