Can anyone do an oasis for me please?
Sicksoh
Shaunavon
Hey hoping someone can run an oasis for me please.
Vin #
1FTWW31P46ED25753
If you could pm me the results or email them to ehorn@ live.ca
Much appreciated thank you so much
Strokethis34
West Virginia
2748109 S07 9 .6 CYPRESS MOTORS (S.C.)LTD. 15906 24-JAN-07 * 9J460 * 080314A
Customer Comments CHECK ENGINE LIGHT DIAGNOSIS DIESEL
Tech Comments 25599 25599 CHECKED FOR CODES, FOUND KOEC P0470, P0528. MON ITORED EBP, MAP AND BARO PIDS, FOUND THAT ALL C ORRELLATE CORRECTLY WITH KEY ON ENGINE OFF. CHE CKED FANSS PID, FOUND THAT FANSS PID READS CORR ECTLY. CHECKED WIRING TO EP SENSOR, FOUND THAT WIRING IS TOO CLOSE TO HEATER HOSE. REPOSITIONE D EP PIPEAND INSTALLED NYGEL INTO CONNECTOR. CUS CODE E29, CON CODE 43 12650D 0.2,
Details 4886218 S07 19 1 CYPRESS MOTORS (S.C.)LTD. 33152 05-NOV-07 * 9D477 * 086876A
Customer Comments CHECK ENGINE LIGHT IS ON BLOWING BLUE SMOKE AT STARTUP
Tech Comments 53353 53353 CHECKED FOR CODES WITH IDS, FOUND KOEC P0470. P ERFORMED IDS BASED EGR TEST, FOUND THAT EGR VAL VE WORKS PROPPERLY. CHECKED FOR EP SENSOR WIRIN G RUBBING ON HEATER HOSE, FOUND THAT EP SENSOR WIRING RUBS ON HEATER HOSE. CHECKED FOR CHAFFIN G, FOUND NO CHAFFING PRESENT. REPOSITIONED EP S ENSOR TUBE AND CLEARED CODES. ROAD TEST, FOUND THAT NO CODES RETURNED. CUS CODE E29, CON
Details 7759802 E72 32 22.9 CYPRESS MOTORS (S.C.)LTD. 54061 10-DEC-08 6C3Z 6049 AA 096216A
Customer Comments CHECK ENGINE LIGHT WAS ON BUT IS NOW OUT, CUSTOMER HEARS A LOW PITCHED WHISTLE WHEN DRIVING ESPECIALLY AT HIGHWAY SPEEDS CHECK TURBO FOR OVERBOOST AND FOUND RUST UNDER V
Tech Comments 87003 HEAD GASKETS CHECK FOR LIGHT, KOEO SYS PASS, CONT P0266, KOER SYS PASS. INJECTOR KOEO SYS PASS AND ALL INJECTORS ACTIVE. POWER BALANCE AT THIS TIME IS ALL EVEN. SUSPECT A POSSIBLE STICKY #2 INJ WHEN COLD. CHECK OUT VEH FOR NOISE. CHECK RAD CAP AND FOUND IT LOW AT 13 PSI. REPLACE. CHECK ENGINE FOR POSSIBLE HEAD GASKETS , CONDUCT COOLANT PRESSURE TEST AND FOUND PRESS EXCEEDING 24PSI.WILL
Details 7958791 S07 32 0 CYPRESS MOTORS (S.C.)LTD. 54061 10-DEC-08 5C3Z 6K682 CARM 096216B
Customer Comments TURBO SEEMS TO HAVE A LOUD WHISTLE WHILE DRIVING
Tech Comments CHECKED VEHICLE FOR TURBO WHISTLE,FOUND THAT THE TURBO IS OVERBOOSTING,REMOVED TURBO FOR INSPECTION AND FOUND THERE TO BE RUST UNDER THE VANES AND IN THE HOUSING,REPLACED THE TURBO AND ROAD TESTED, FOUND GOOD SMOOTH POWER WITH BOOST UP TO 24 PSI WITH GOOD EGR RESPONSE.RELEASED VEHICLE
Details 9542420 2169D 58 0 JUBILEE FORD SALES (1983) LTD 90098 07-JAN-11 * 3049 * 84499801
Customer Comments CUSTOMER PAID FOR BALL JOINT REPAIR ON PREVIOUS RO.
Tech Comments REFUND FOR CUSTOMER PAY REPAIR THAT WAS COVERED UNDER ESP WARRANTY.
Details 9760816 2169D 62 9.5 CYPRESS MOTORS (S.C.)LTD. 98524 03-JUN-11 3C3Z 6A642 CA 114737C
Customer Comments COOLANT LOSS FROM DEGAS BOTTLE WHEN TOWING
Tech Comments 158560 RESTRICTED ENGINE OIL COOLER CHECK FOR LOSS OF COOLANT.PERFORM TSB 09 08 03, PRESSURE TEST COOLING SYSTEM, NO SIGN OF EXTERNAL LEAK . USING RADIKIT VACUUM SYSTEM AND CHECK FOR LEAKAGE, NO LOSS OF VACUUM. INSTALL COOLING SYSTEM PRESSURE GUAGE AND HIGH IDLE ENGINE TO CHECK FOR POSSIBLE CYLINDER HEAD GASKET LEAKAGE, PRESSURE IN SYSTEM STAYED BELOW 19 PSI. CAP
Details 9760817 2169D 62 1.4 CYPRESS MOTORS (S.C.)LTD. 98524 03-JUN-11 BL3Z 4676 A 114737E
Customer Comments OIL LOSS FROM RR DIFF PINION AREA
Tech Comments 158560 158560 CHECKED FOR LEAK.FOUND PINION SEAL LEAKING.REPLACED PINION SEAL AND NUT.DIFF WAS 1 L LOW.FILLED DIFF..LEAK NO LONGER PRESENT.
