2000BigDirty7.3
- Joined
- Oct 16, 2014
- Messages
- 18
- Reaction score
- 0
Hey guys, idk if im fkn doing something wrong our what but this is the second time I've rebuilt the front axle in my 250, its not gears im having issues with, its the pass side long axle shaft, I replaced both the dust bearing seals, axle seals, needle bearings and warn hubs, just after christmas, havent even used 4x4 once, yesterday I hit a bump and once again the front end started vibrating.... What could be causing this, when it starts vibrating it takes out the needle bearing then the dust bearing hub seal then everything else! Getting anoyyed!!!
Sent from my HTC One M9 using Tapatalk
