Carli braided rear brake lines
BIG JUICE
Valrico FLA
Carli says you don’t need them until 4.5” but I have a set on my 2.5”. Yes frame to axle, have to buy caliper lines separate because they need to modify the bracket. No one includes the caliper lines in kit. I had two sets of rear lines. I just ordered the caliper lines to swap out from crown. $56 from them
HeavyAssault
Middle, VA
Okay. Just to clarify. I have two brake lines that drop from a frame block in the area of the DEF tank. They each feed their own side/calipers.
I just want to be sure it's two lines that are used from the frame block down to the axle. I understand these lines are not for the calipers.
