Ccv is rerouted
6speedsd
Olive Branch, MS
Did this last weekend. My question is how much vapor should be coming out of that line? I just dumped it behind the cab, but it stinks to high hell so I'll probably reroute it back to the intake after some sort of separator. But, sitting in traffic last night, when the wind is right I can see vapor coming out from under the truck. Just seems like alot to me but I don't know what the norm is. It was like 75 degrees outside too, so it wasn't more noticeable because outside temps.
HOOV3R
Central PA
What size hose did you run? 6.0s breath pretty heavy, but blowby may be increased on a higher mileage / not well maintained engine.
Mikeh1725
Grapevine, TX
When mine is warm you can see the vapors making little puffs but I'm not worried.
Mine is dumped at the front bumper just below the plastic piece; no smell even with rotella oil.
6speedsd
Olive Branch, MS
I might try running mine farther back before i reroute it back to the intake. Either that or do like you said yours is and drop it behind the bumper.
I need to get underneath and make sure I'm not blowing oil out. I guess if its not bad enough to blow oil then its ok.
Mikeh1725
Grapevine, TX
You'll probably get some oil blowing out (hints the wet boots with the stock ccv) but if it's more than a few drips you have other issues.
6speedsd
Olive Branch, MS
I haven't seen any oil yet on anything. It's just the smell that I can't take. Going to run it farther back this weekend and see if that helps.
Josh@DirtyDiesels
PA
Mine is just routed right down next to the oil pan pretty much. Always puffing a little bit, nothing crazy. Idk if I'm just used to the smell or if it just doesn't bother me LOL
HOOV3R
Central PA
I routed mine all the way behind the fuel tank. Only has a slight haze on really hot days or when the oil temp is up a bit.
