So I parked my truck for 6 months I was not able to run the truck because I was out of state when I returned I changed oil fuel and fuel filter and in the 6 months of being gone I had a few parts I installed them went to start the truck and it would not start ficm good oil psi good motor just sounded weak took it to ford they said the ficm was bad but I just installed a new one when i got back then they said it was a ground they fixed that then they said 3 cylinders were low on compression and I needed a new motor but when I parked it it was fine so my question is how would the motor go bad when it wasn't run in the 6 months can a motor go bad from being parked
