imelmo
- Joined
- May 18, 2011
- Messages
- 6,632
- Reaction score
- 2
Got everything set up to do the compression test on ZMBYKLR today. Teated one of the front cylinders first for a baseline and it read a little under 400psi. Hooked up to do the cylinder that had the broken rocker arms and it jumped up to 500ish psi. Pulled the tester out, turned it over, and realized the stand pipe was pumping oil still (even though I drained it) and must've gone in the cylinder thru the glow plug hole. So two questions.
First, can I remove the standpipe while doing the compression test so it's not pumping oil out into the cylinders?
And two, what's a good way to get the oil out of the cylinders? It appears to only be in the rear two. I'm thinking I'll just try and rig something like a straw up to a shop vac and suck it out the glow plug hole unless there's a better/easier way.
