Coolant leak
04 f350
Got up for work this morning and noticed three different coolant leaks under my truck, two are coming from above the starter and the other is coming from the lower radiator hose(looks like it's just the clamp getting weak) so I popped the hood and the underneath the turbo is a puddle, I have a egr delete so am trying to convince myself it's only somthin that's come loose or an oring maybe, is there anything else it could be for me to look for when I check it out?
SDER1
VA
I would check the hose on the j-tube of the EGR delete...read many posts that the clamps need securing. Also ensure your hoses are tight into the T-stat housing.
