Crankshaft Walk??
Ok guys. This truck is going to drive me absolutely crazy. This is my 4th radiator I have gone through in the past 3 months. At first I thought oh it's just a faulty radiator. But then after the 2nd one I got looking and every time I would fully accelerate my truck the whole clutch assembly would move forward therefore mashing the radiator therefore putting holes in it. Now I have replaced the whole fan clutch assembly about 2 years ago. But I just started this problem about 2-3 months ago. I heard that these trucks crankshafts can walk. I don't know what's going on. Please help if you can!!
If I have bad motor mounts would it do this?? And where are the motor mounts located??
Magnum PD
VA
Both sides of the engine. 3 bolts each on the block, 2 to the cross member. Look for cracks.
Arisley
Arlington, Texas
If you had crankshaft walk, it wouldn't do that unless it came through the front cover. The crankshaft is not attached to the fan.
