Barnhartal
Does anyone know of anyone that makes turbine shafts. Specifically I'm wanting a van turbine wheel but on a larger shaft. I've got a Gt3776d turbo. The center section has the same mount as a gtp but has a significally larger shaft and bearings. The back plate is the same style as a 38r but a little larger, so 10 mins on the lathe it'll fit a 38r housing.
So if I could have a turbine wheel made I've have basically an sd66 but with stronger shaft and bigger bearings.
