D50 ARB Locker
NEVRNF
NW IL
I have a used ARB i just removed from my damaged D50 front axle. Work perfect. I had to replace the housing and the new one is a D60 so this cant go back in. $550 shipped.
NEVRNF
NW IL
Just the locker and bearings. I will also include any shims i have from my install. I am still running my rear locker so i need the compressor.
Dieseldan
I may be interested, just wondering what was damaged on the D50 axel you removed it from?
NEVRNF
NW IL
I seized the pinion bearing at the yolk due to inproper installation by someone trying to help me out while i was not watching. :doh::doh:
Locker and bearings are undamaged. I will also include the solenoid that would go at your air supply. The only thing i wont have is the hoses as i am planning on replacing the locker down the road.
NEVRNF
NW IL
Bringing this back up. The diff is damaged and needs a replacement cover and thust washer. It is the 1st design from ARB. I am open to offer for this before i toss it to the scrap guy.
NEVRNF
NW IL
It came out of a 01 F350 with a staight axle. you would have to check with ARB. It is a Model RD50
