Will the d66 off my obs fit on a early 99
Apr 1, 2013 #1 97spoolinstroker New member Joined May 18, 2011 Messages 457 Reaction score 0 Location brighton colorado Will the d66 off my obs fit on a early 99
Apr 1, 2013 #2 rustbucket New member Joined Mar 25, 2013 Messages 166 Reaction score 0 Location Fallon, NV No the D66 has a four bolt flange on the exhaust housing. Superduties use a v-band clamp
Apr 2, 2013 #3 Short Bus New member Joined May 18, 2011 Messages 1,131 Reaction score 0 Location kansas Not to mention they mount different to the pedestal
Apr 2, 2013 #4 rustbucket New member Joined Mar 25, 2013 Messages 166 Reaction score 0 Location Fallon, NV You could get it to fit but you would need everything off an OBS to convert over. (Up pipes, pedestal etc...)
Apr 2, 2013 #5 K kampy New member Joined May 25, 2011 Messages 155 Reaction score 0 Location Rio Rancho NM All you should need to put it on would be the collector and pedistal, everything else should fit fine Edit: not sure about the DP flange size Last edited: Apr 2, 2013
