gnxtc2
I did some valve spring calculating before I do my swap.
I have Comp 910 sitting in the box.
Specs-
92lb @ 1.850
300lb @ 1.350
coil bind - 1.280 (1.330 max lift with .050 safety margin)
Factory specs for valve springs:
71-79lb @ 1.833
225-249 @ 1.352
Gives us a total lift of .481
The stock cam lobe lift is .253 on both Intake and Exhaust
So to get rocker arm ratio - .481/.253 = 1.90 rocker ratio (If I did it right)
So we can agree that max lift in the 7.3 is .481?
After countless hours of search on PSA and PSN, most are installing the 910springs in 1.750 - 1.780 range.
1.750 - .481 = 1.269 (past coil bind)
1.780 - .481 = 1.299 (not coil bind but not within .050 for coil bind)
By my calculations, the Comp 910 are at coil bind unless installed at factory spec or at 1.811.
99lb @ 1.833
107lb @ 1.811
Someone please correct me if I calculated this stuff wrong.
Thanks
Billy T.
[email protected]
Specs-
92lb @ 1.850
300lb @ 1.350
71-79lb @ 1.833
225-249 @ 1.352
99lb @ 1.833
107lb @ 1.811
Thanks
Billy T.
[email protected]
