Been thinking about this a little since the truck died once last week. Last week it died on a cold start up when it was put into reverse. It runs normal idle rpm, but has a noticable load on the motor when in gear (EGT is also 50F higher than when in park or neutral). The converter has always been tighter than any PSD stocker Ive driven or other automatics (PO was told the BTS is like this).
The tuning also runs more ICP than my OBS (850 @ 14%) and its always had an issue if you crack the throttle and release, it will fall below typical idle and shudder before coming back up to idle. Often wondered if this and the gear change issue were related... otherwise, its a fun truck to drive and works perfect.
Thoughts?
Thoughts?
