I also noticed a slight amount of play in the plastic bushing on the end of the clutch rod. I may put a new plastic bushing in there....
I know they sell an improved hyme joint fix, but this one lasted 20 years... and I only use the truck part time.
something to check if you have any problems starting the truck without stomping the clutch all the way to the boards.
I soldered them together then used shrink tube.
then plugged the switch back in. Hopefully the cruise will still work, if not I will do the same for the other 2 wires.
