Ford460power
So recently installed fuel psi gauge, blue spring upgarde and an air dog 150. At idle I'm making solid 70psi, but under wot still dropping into the 50s psi range. Before I did the air dog system I had about 60 psi at idle and it would dip into the 40s under wot. Should I be looking into a regulated return system?? I have changed both the hfcm filter and the fuel bowl filter. How much psi drop is acceptable to wot?
