PSD715
So i have a 4 line setup, front pump is jic fittings and back pump is SD style. Well, one of the SD lines got a pinhole and got worse fast. So I was going to switch to 2 line setup to get me by, as I wasn't planning on even having the truck together yet, but the wife's car got totaled, so no choice.
Rather than plug one outlet on each and run one head off each, could I run a line between the two pumps just to be sure I've got even pressure all the way around? Is this a really bad idea in some way? Or maybe just not that necessary?
None of the lines I have are long enough for a crossover btw.
