E- fuel on back of head ?
ryanss22
upstate central ny
I had read somewhere that its possible to drill out the fittings on the back of the head for more fuel flow, is this true? If so what size can it be bored out to? What exactly is being bored out? As I just hooked up to what was on the head.
Biggreen96
Visalia , CA
If you have steel fittings going at the back you can get a .250 drill bit and drill it out. Dont try to do it to al. Fottings
pontiacross
diesel innovations sells some fittings that replaces the plugs in the back of the heads so you can feed it there instead of the 1/8 pipe hole in the side. That is what I am running but not sure if it helps or not
