riverboy460
hi guys I pulled out my trans Friday to install a john woods transmission. removed the cooler lines to clean out with brake cleaner and blow dry. I also installed a 6.0 cooler. now I need to re run the cooler lines. I just need someone to confirm my routing so I don't mess it up. (not like I could that I know of cause you can run it either way in or out on either side that I know of).
I don't have a otc radiator cooler.
I think it routes this way oem. please confirm if you know for sure. drivers side port should be the inlet from the front of the transmission line and the return should be the right side and the rear transmission fitting. is this correct.
thanks for the help guys.
