E99 F550, 6 spd, flatbed, Setup Work Truck
B.Warning
NE Missouri
Well, this truck is for sale. I replaced it with a single axle semi and simply do not need 2 service trucks. I'm selling it completely setup as you see it. If it comes down to it I'll include the welder for a additional $2,000 as I'm wanting to upgrade to a Lincoln sa 200 anyways. This is a great truck that'll pull anything and haul whatever will fit on the bed. I drive it every single day, and would take it anywhere. (you won't get there very fast as it's top speed is 70mph without sounding like a rod is wanting to escape) LOL The 4:88 gears make up for it in the towing department.
218k miles
12ft flatbed w/gn hitch
Ranch hand bumper
05HD headlights
Smoked cab lights
Updated 40/20/40 seats
Stg 1 full force single shot injectors
TS w/tyrant tunes
KC Clutch HD Clutch (holds very well)
5"side exit exhaust w/muffler
Parts replaced within last 12 months
Replaced motor with e99 motor due to old one having low compression on a few cylinders. Motor swap included, manifolds, up pipes, starter, complete with everything. At time of swap new motor had 150k miles. I have paper work verifying mileage, and work was done by a very reputable local shop that does all my work. Clutch was installed at the same time.
Rear brake calipers, pads, lines
All new u joints
$8500 for a setup truck minus the welder and tools
$10,000 including the welder
Tool boxes are Montezuma 30"top boxes, knapheide under body boxes, and pro max low pro side boxes.
http://imageshack.us/a/img600/6601/hfz4.jpg
B.Warning
NE Missouri
WHY NOT
Carlyle IL
10000 for the truck with the welder 8500 w/o = $2000 for the welder? You must have some special kind of math lol
Sent from my I fone 5
