Preston_leslie
Maybe it's been said before or maybe you guys already do it, but if you are pulling your turbo or plan on pulling it remover the oil filter housing it's 4 bolts and the fuel lines but makes pulling and resetting the turbo much easier at least for me. I went straight in with the turbo hit all 3 bolts and up pipe/down pipe clamps first go. Literally had the turbo back in and bolted down in under 3 minutes. When i removed the turbo I still had oil filter housing in and it was the same old wrestling the turbo out. Going back in was cake. Let me know some feedback on your thoughts?
