Duece
Does anyone know if all the PIDs (in the new 3.0 program for Edge) will work on the 2003 6.0l? Hopefully all the PIDs will work now.
Ford 2003-2007 6.0L Powerstroke
Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Pressure, Engine Oil Temp, Engine RPM, Engine Run Time, FICM Voltage, Gear with TCL, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle
No they wont. I talked to edge and they told me that the 3.0 update version is the beta test version....it's just becoming official now and that there will no new PID's to monitor.
I listed all avail pids and the ones that aren't for the 03 in my first post
it's not a Beta it's available for download as a full release last Week
and it has fixes and new pids and other managers you should get some use out of the release
give it a go IMHO
