kersey1999
I just finished changing out my EGR cooler and oil cooler due to the infamous white smoke issue. However I started the truck up this morning after the install and it was still smoking a bit, not as bad as it was before I did the change. My question to all you guys is this common to still smoke a little after a change maybe from residual fluid in the intake chambers? I did clean out the intake the best I could but feel maybe still some in the internals of the motor. I also changed the oil, oil filter, and fuel filter while I was in there. Any one have a like or similar issue with their 6.0?
