egt gauge?
StrokinNsmokin
Battle Creek, Mi
Mine is reading at like 2000 degrees when starting the truck and then backs down sometimes to 1800 or so. What would make it do this it just started out of the blue.
cfdeng7
CT
:whs: what brand is the gauge? Check for chaffed wires too. If not the sender or gauge could have took a chit the bed
CSIPSD
Bend, OR
What brand and model gauge?
Check your ground connections and as well the power connections. Also check to insure the probe is not loose in the mainfold.
Tree Trimmer
if it reads max'd at start up, and then drops when idleing, i would say that he has the two wires backwards off the probe, if possible with his guage.
when i hooked up my water, i had them backwards, and it did just what his is doin. read high, then fell as it heated up.
StrokinNsmokin
Battle Creek, Mi
Its a bullydog guage. I bought them about 5 years ago when I got the truck I chercked the fitting thats tight i'll check the grounds next thanks guys
