egt probe
Irontx
Texas
:whs: Little flat spot close to where the manifold bolt slides past to go into the head.
jdgleason
Fort Collins, CO
Pre turbo (in themanifold) is usually a better spot to put it. Temp readings are more accurate, and then you are less likely to fry a turbo. Post turbo temps should be cool enough not to alarm you- which is the whole reason to have a pyrometer lol
Donnie1
Cole Camp, Mo
Should be on the drivers side at the rear of the manifold at the bend. Pretty easy to get a drill in there from the bottom.
Make sure you you use several different bit sizes to get to the desired holse size.
