EGT probe
BCpsd97
Hey guys,
Last night on the highway my egt gauge just dumped to 0. no reading at all. Before this it worked for the several months I have owned it. Gauge is Autometer Z series. Is the likely culprit the probe? Just looking for some experience before I go digging around senselessly. Thanks!
littleredstroker
where the antelope play
Check all connections obviously.. I chased similar issue down for weeks. I was told the thermo couplers rarely go bad so I was focused on everything else but it was in fact thermo.
Check wires at firewall to make sure they aren't bent or cut
sent while looking at a hole in my block
BCpsd97
I will check the firewall first because I was messing around the other night wiring in an amplifier, thank you, I most likely would have not come to that conclusion!
CSIPSD
Bend, OR
More then likely its a ground issue. Make sure the two pyro wires are not touching or have not chaffed the wiring at all.
Nice thing about Isspro gauges, if there is a problem the gauge goes to MAX reading.
