Lang
- Joined
- Sep 10, 2012
- Messages
- 774
- Reaction score
- 0
Trying to fix my drivers door lock... When I bought the truck the unluck button worked slow, then finally stopped. (Lock side still works, have power to switch, pretty certain from continuity test i did switch is good)Tore door apart to find a aftermarket actuator. Took that out, broke down OEM actuator, motor was fried. So ordered aftermarket ones to replace. Go to install, find I have no power from unlock button to connection at actuator(pressed unlock, no power, lock have power) . Not sure if wire grounded out from the switch, wouldn't that pop the fuze making everything in that circuit stop? I'm looking for some direction or a schematic to follow what wire goes to what in my door
