I started replacing my engine harness, got almost done and am now stuck at the ckp. Is there a trick to getting the plug fed thru, or do I need to start disassembling things to get to it? Any help is greatly appreciated!
Thanks for the reply! Is there anything that needs to b removed to get to the bolts for the a/c compressor, and does just unbolting it give enough room without having to disconnect lines too?
