Yes its possible. How complete is this 06 motor? If it has an intact 06 harness use it. The motor mounts are slightly different between the 03 & 06 motors and I've always put the mounts that were on the original motor on the swap motor. Before you put the 06 motor in do all the high pressure oil system updates.
