F250 rear end swap question
Tn
Will a 2006 gas burner F250 rear end work on my 2002 Diesel F250? I really only need the center carrier (I think thats what its called). The part holding the clutches and small gears to make the limited slip work, that the ring gear bolts to. Mine has some pretty good wear to it and I found one in said gas truck for a dang good price. I want to bolt my gear to it along with new bearings, shims etc... and install. Will it work?
