Dirtclod
First off I want to say I've never had a problem with temps on this engine or the one I replaced at first of the year. When I made the cross country pull the temp gauge rested in the same spot the whole time after it warmed up which is bout a quarter of the way. Tranny temp always stayed between 160-190. Even those long hills through Nevada held down to the mat for 15-20 min at 2600rpm at 70 mph temps were fine. I did stop after one of those pulls at the edge of evening and degas bottle had a small crack in it on top but fixed it with some epoxy.
Here's my lil issue: after I got out here to the Bay Area I noticed a squealing sound up front and determined it is the Fan Clutch. I replaced it a year and half ago cause it got pretty rough. It was starting to get a lot louder until yesterday and it's stopped the squealing. I wonder if it was locked up and unlocked itself. I had actually called and had one waiting on me at autozone cause it's under warranty. I was wondering back then could it be an issue with the water pump,but the fan clutch replacement fixed the noise and no issues except that main drive pull-up seems a lil out of balance. Has anyone had issues with fan clutches,and that pulley being out of whack?
