fixing to possibly do an oil cooler
Stillstrokin8
Title says it all... if I end up having to do a oil cooler I know I'm going to do the stc fitting as well... anything else in there I should take care of?
Stillstrokin8
Ya Ima be super careful when messing with the egr connection to the up pipes and the turbo when I pull it and I think I'm going to get a spare cooler and weld it shut
Stillstrokin8
I'm really talking bout things I won't be able to get to once I put the intake back on. Is the stc fitting the only thing under the intake?
Bigred91
Georgia
You can do the stc fitting without pulling the intake unless it's an 03 engine, but egr delete, oil cooler and stc fitting/hpop are all that's under the intake. Make sure that the big oring for the coolant passage to the intake is either still there when you go back together or you replace it.
