stereodesigner
- Joined
- Jul 15, 2013
- Messages
- 72
- Reaction score
- 0
Warning:: multiple issues beware
I've browsed through others threads on my issue but non of them relate/or have the same mods that i have so I wanted to be sure on my issue.
Truck is a 03 f250 6.0 265k
mods are egr delete, upgraded turbo drain tube, 4" straight pipe, tune is vivians looney, stock studs.
I noticed a week ago at 55 in od my truck would start to buck/stutter once it warmed completely up the problem somewhat went away. figured injector was going but threw no codes.
every once in a blue moon the truck would puff a good cloud of white smoke when starting in the morning (figured normal 6.0 injector stiction)
The last two or 3 months my degas container would be under minimum so I'd add some maybe 1/8-1.4 of gallon, few days later it would be back at the same low level (but it would never go below that one low spot).
Finally today i happened to look under the hood on two occasions and noticed it almost looked like the coolant was bubble inside the degas bottle (but cant tell if there was just coolant re-entering the bottle). And just now the truck is fully warmed up sitting at a red light it starts blowing white smoke, not nothing heavy just noticable so I drove it home and let it sit running and there is barely some white smoke still coming out.
My coolant temp stays in the mid 190s and my EOT stays 195-200.
Lowest I have ever seen my ficm drop is 47.5v.
So whatchal think?
Please help :flush:
So whatchal think?
Please help :flush:
