Sportchassis06
- Joined
- Dec 11, 2015
- Messages
- 830
- Reaction score
- 0
I purchased this,to try to recitify a shifting issue ,My truck has since had from pump failure,so I have no need for this.This item sells for $799 plus a $350 core.and shippingNo core needed from me.I only opened box to take pictures,and left it wrapped in the plastic the way it ships.As you can see the Strategy is included:This is the description from Revmax's website.
Perfect For Modified or Stock Engines
Increased Transmission Durability
Faster 1/4 mile Times (Street/Strip)
Complete Disassembly
Thorough Hand Washed Cleansing Process Removes all metal and clutch particles
Hand Assembled by Qualified and Caring Professionals!!
Aqueous Solvent Cleaning
Custom Reprogramming Shift Kit
Increased Line Pressure
Increased Torque Converter Lockup Apply Pressure
Modified Fluid Passages
Custom High Performance Shift Valves
Custom HIgh Performance Spring Assemblies
Shortened Shift Time
Crisp Shifts, Not Neck Snapping
Complete Computerized Testing Of Valve Body on Zoom Hydratest Valve Body Dyno
VALVE BODY MUST BE PROGRAMMED TO THE VEHICLE AFTER INSTALL. THIS CAN ONLY BE DONE WITH A FORD IDS SCAN TOOL!!!
