Ford 7.3 Low/No Boost/HPOP?
NitroJoe
Ft. Lauderdale, FL
Hello army!
I need a few second opinions before I start down the next rabbit hole.
Story behind truck: Bought from a negligent owner who performed no maintenance. Oil leaking everywhere. 350K on dial. No idea on what if any parts were changed.
Here is what I did to correct the truck before we get to the point:
  1. Rebuilt turbo (360 bearing, WW, new 1.0 ex housing)
  2. Turbo pedestal with delete and resistor in plug.
  3. New bellowed up pipes
  4. New IPR, new ICP (ford or equivalent)
  5. New LPOP
    1. Reservoir was slowly bleeding down overnight
    2. Cleaned everything, cleaned check ball in block under housing
    3. New gaskets for oil reservoir housing, HPOP, and fuel filter housing
  6. CNC line kit as well for HPOP
  7. 6.0 intercooler, new boots, all cleaned
  8. PCV reroute to filter and reinstalled back to intake
  9. Oil Cooler rebuild (ford parts)
  10. Coolant flush
  11. Oil change 15w40
  12. Bypass oil cooler installed as well (Amsoil)
Now what is happening....
No boost/Low boost - like nothing, at WOT I might see 5 lbs occasionally, but I have to really force it (like a race car). Takes over 1/2 mile to even get that much at WOT
She idles well, no surging, no loping.
Bit of a hard start, way better after I replaced LPOP, verified oil in reservoir
Autel scanner while driving
RPMBarometric PSIExhaust Back Press
PSI
Inj Contr Press 1 PSIInj Contr Press 2
PSI
IPR %
68014.9516.1547448123.8
64514.9516.4450755924.6
140014.9516.88755.65730.9933.59
160014.9518.69839.77858.6235.93
181914.9518.791109103848.43
258214.9523.321430138656.64
307614.9529.041649169463.28
The truck DOES report a P1211, but nothing else.
Here is additional troubleshooting I performed:
  • Verified oil level in resoivior
  • Verified fuel pressure (riff raff gold spring) is showing 75PSI, on list to change to silver
    • Test also performed under load and WOT, no change 75 PSI
    • Should also rule out tank issues (although I do have a frame mounted filter no debris)
  • Pressure tested charge side of turbo fixed any leaks, intercooler good.
Based on the troubleshooting, chart, and research here is what I am thinking.....
  1. Map sensor is bad, value should be changing some
  2. Possible bad oil?
  3. P1211 Could be a ton of things but
    1. leaning towards weak HPOP
    2. possible bad injector O rings, oil bleeding past?
Let me know what you think.
Thanks in advance,
NitroJoe
Mesa, AZ
Icp is super low, have you tried running it with it unplugged? You could have a harness/pigtail issue. You also say ford or equivalent, was it ford or was it a pricier aftermarket who knows the quality one?
Also, if it’s got 350k on it and wasn’t taken care of, injectors could be flat wore out. Possible with the pump as well.
NitroJoe
Ft. Lauderdale, FL
IPR was from RiffRaff, ICP I think from Blessed, not 100% on that one.
I'll try with it unplugged. Injectors have passed all the IDM tests and buzz 'seems' ok.
I have a spare set of injectors and pump but not sure their condition either, its a crap shot unless I send both out which is $$$.
psduser1
on the road
If that reading is 1600 psi at 3k rpms, you aren't building oil pressure.
Id start with new/reman injectors.
The pump should build 22-2400 psi, even if it's worn out, at those rpms.
You may still get a 1211, just means it's not building the called for pressure.
Sorry, advertised service life for injectors was only 200k miles, lol.
NitroJoe
Ft. Lauderdale, FL
Ya I'm leaning towards injectors as well now.
Replaced the map sensor, now getting proper readings.
Replaced HPOP with a brand-new atlas, same issue. It does start better and act better but limited power still.
ForScan injector contribution test shows nothing.
So, its loosing pressure somewhere and the only thing I have not replaced is the injectors.
On a side note, can anyone help me understand Torque converter slip actual vs desired? I'm showing 938 rpm desired @ 2455 rpm and 193.75 actual. I do not know if this is something to be worried about or not in this troubleshooting process.
Thanks again everyone, I appreciate your guidance. :)
Mesa, AZ
That’s not really to be worried about. Now if it was commanding 0 slip, and you had 200+ that would be an issue and indicate your converter isn’t locking
NitroJoe
Ft. Lauderdale, FL
Update and an ask for advice.
I ended up with 2 sets of injectors and need help picking a path.
1. Stock injectors with unknown mileage (supposedly <80K) and they look good physically
2. 205/80 FFD hybrid injectors with less than 20K from a known good source
I have no cross contamination that would suggest bad cups...
So do I invest $800 in a hydra and jellibuilt tunes (the only one I'm aware of that does hybrid injectors and cups)
OR
Gamble with the unknown set and Re-Oring them and install?
Thanks....
NitroJoe
Ft. Lauderdale, FL
Update:
Last weekend I changed the injectors using the stock set I had laying around. Did spot check compression test, showed 400.
Old injectors came out smooth; inspection showed no bad O-rings or other visible indications of issues. Cleaned cups and installed injectors using alliant O-ring kit. Also did an oil change.
Didn't have time to drive her 50+ miles, but so far other than a heavy vibration at idle she is running much better. Coolant is clean, fuel is clean, no contamination.
PS still low boost BTW, at full throttle its only registered 5psi on the gauge. She also ran like real crap until I did the throttle pedal re-learn procedure below:
  1. Ignition on and count to 3
  2. Depress/release pedal 5 times firmly and quickly
  3. Count to 10 and full press pedal down
  4. Count to 12 and release pedal
  5. Count to 10, depress pedal again
  6. Count to 10, release pedal
  7. Turn off ignition, wait, then start engine
This made a huge difference. Even with low boost she is an entirely new truck. I'm planning to pressure test the system to 20psi for a smoke test.
May also do a transmission relearn as well, not sure yet.
Mesa, AZ
Heavy vibration at idle sounds like a misfire. May have knocked an injector connector off when you installed one of the valve covers
NitroJoe
Ft. Lauderdale, FL
I spoke to soon. Your ability to troubleshoot over the internet is amazing, ty.
Something is definitely wrong. Codes came out last night 1211 and 1211-C. Cylinder delta in 4,5,8 bounce between 3-4-5% variation with the others sub .2%
I parked the truck until I can get my buddies autel. Looking like the spare set of injectors may be compromised or install issue. never say never but I have done enough of these installs the process should not have been it. I should have paid the $$ for the tune and installed the hybrids. Diesel at 7 went cheap and how probably have to do it again.
NitroJoe
Ft. Lauderdale, FL
No misfires reported on scanner for any of the testing. New atlas, HPOP Lines, LPOP, and seals on stock injectors. All injectors pass basic buzz and IDM inquiry checks from autel. P1211 keeps being reported after attempting rapid acceleration. Got the 1211-C once time, once cleared did not return. Idle is not shaking the engine anymore but still have no power and takes almost 1/8 mile to get to 3lb boost.
Injector 5 & 8 reporting over 2% and 4% Delta consistently after warming up. Some additional chart information below.
Appreciate any insight before I tear into the truck again.
RPMBack PressICPIPRMAPWastegateSpeed (MPH)Delta1Delta2Delta3Delta4Delta5Delta6Delta7Delta8Converter Slip ActualConverter Clip Actual
671​
16.3​
531​
25​
14.61​
0​
0.56​
0.25​
0.5​
0.5​
2.06​
0​
0​
3.81​
452​
1020​
2192​
18.64​
1310​
52​
17.48​
0.38​
18.44​
206​
1020​
2057​
23.67​
1495​
57.81​
17.77​
0.38​
25​
471​
1020​
Mesa, AZ
1211 in my experience tends to be icp sensor related, then a fuel related issue. Typically plugged pickup in the tank, there’s 2 little filters inside it that get plugged up after 20+ years of shit getting out in the tank. Last is typically an actual hi pressure oil issue, at least from what I e run into. If fuel pressure is good, and icp and pigtail are good, then that leads to an actual hi pressure oil issue. When you did the pump, did you replace the ipr? What brand was it replaced with if so, and where did you get it? Does the ipr still have the tin nut on it? When you replaced the pump did you remove the springs and check valves under the line fittings or leave them in? Whose hpop lines did you use?
NitroJoe
Ft. Lauderdale, FL
The IPR/CPS/ICP where replaced about 2 years ago before the truck started having issues. All were purchased from Blessed Performance. IPR/CPS=Alliant ICP=DieselSite. I have a spare ICP I can try.
Fuel pressure is good at idle @55psi. I do not have a long enough lead to test fuel pressure under load (which I am trying to find). I also saw a test to put a vac gauge on the supply line of fuel pump to determine if tank is suspect. I did replace the screen many years ago for them b4 I bought the truck.
I did not tear the ipr apart and check it. The tin is on and tight. When I replaced the HPOP pump I removed the springs and installed per the CNC Fab instructions (all lines from them).
Mesa, AZ
How did the o rings on the ipr look? I agree the icp looks low, checking fuel pressure under load is necessary. Idle has very little demand for fuel. Same with checking vacuum on the supply side of the pump, it can read right at idle, it’s not until it comes under a higher demand that you start seeing issues.
Funny thing about this code is most of the time it’s fuel related, even though it calls out icp specifically. Seen lots of people replace hpops, iprs, etc chasing this code only to find they’ve got 2psi of fuel pressure under load. I’m not exactly sure the strategy behind the code, but I think it relates to lack of rpm not spinning the pump fast enough to build icp that’s desired
NitroJoe
Ft. Lauderdale, FL
TY All, I'm waiting on hose barbs and fuel line so I can test. Also found spare (no name) ICP & IPR. Will start with fuel tests first. I'm going to switch to Forscan to try to monitor actual and desired PIDS. I cannot seem to get desired to show on the Autel live data capture.
NitroJoe
Ft. Lauderdale, FL
OK, latest update. Fuel pressure at idle is 75psi it goes no lower than 65psi during full acceleration. Did not check tank vacuum as PSI is so high.
Tried spare ICP and truck would not even start, so spare is bad.
Used forscan this time and got better live data tracking, chart below.
I am still having a hard time finding the PID for desired (made assumption the ICPV is mislabeled in Forscan and is actually desired as PID notes are the same for ICP and ICPV).
Threw the entire 11 min data dump into chatgpt and in no instance are the ICP/ICP > 218 psi, >400 triggers the 1211 code according to other ford research. The IPR looks like is it behaving, but what are your thoughts?
RPMICP, kPaICPV, kPaIPR %EBPV, kPaEPR %
635 (startup)
5375​
5620​
38.28​
116.2​
44.31​
659(settling)
2875​
2729​
19.92​
112.7​
2.75​
1198​
3832​
3540​
24.61​
122.8​
0​
1694​
7742.2​
7380.8​
48.05​
147​
0​
2151​
10539.1​
11310​
63.28​
157.9​
0​
1435​
6128​
6648.7​
37.11​
126.5​
0​
2133​
10070.3​
11300.6​
60.94​
156.7​
0​
840​
3355.5​
2968.6​
23.33​
115.7​
0​
Mesa, AZ
Ok, let’s try some dumb shit here now, cause this really ain’t making sense. You’re only building like 3 psi of boost, right? According to your log, at 2100 rpm you’re around 24psi of back pressure. Your icp does still look low, but I’m now wondering if you’ve got a driveability issue causing the icp code.
Let’s first pull the inlet off the turbo and make sure it spins good. Then, as long as that passes disconnect the down pipe, either off the turbo, or down below around the trans cross member where it bolts to the rest of the exhaust. Then drive it and see if it runs better. Third, let’s boost leak check it if the exhaust test passes. Could have a blown out plenum or intercooler, if it’s a plastic tanked intercooler.
NitroJoe
Ft. Lauderdale, FL
Will do, look for an update next week. I have to step away for some family and work stuff through this weekend. I'll get the test results as soon as I can.
