Power Strokes
6.0 Aftermarket
FPR brand
[QUOTE="Extended Power, post: 1268205, member: 898"] I have used the Aeromotive Marine regulator. No issues at all with any of the fuel system components for the last what??? 6-8 years. Copied from an earlier post of mine: Hellman sump, DAHL 200, Aeromotive 11110 marine grade pump, Aeromotive 12310 Pro Series 10 micron filter after the pump, (Mounted directly to the pump's outlet.) Russel "Y" block, fed into both sides of the front of the block, out the back of the block on both sides to an Aeromotive 13114 marine grade regulator, to a nice sized fuel cooler, to a check valve, and then back to the tank. Use braded stainless steel lines, because the tech guys at the track flagged me when I was using "Blue" hose. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
projectford
Power Strokes
6.0 Aftermarket
FPR brand
