williamallen13
I have a 2011 250 in about 4 months ago I replaced the front and rear brakes with yellow stuff brake pads. A couple days ago I realized my front brakes were squeaking more than normal and now they seem to be grinding. I looked at the front and rear last night and it looks like the front is worn all the way down and the rear are hardly worn at all. has anyone had a problem like this for know what could be causing the front pads to wear so fast? before I changed my front pads and after I was noticing the brakes were sticking so when I would let my foot off the brake pedal it would delay like one or two seconds then the brakes would release.
I ordered powerstop extreme tow brake pads and slotted and drilled rotors so they should be coming in the mail along with two new remanufactured calipers for the front. Hopefully this fixes it.
