Ft Carson Auto Craft Saturday
SOBX
Colorado Springs
I will be out at the auto craft shop on Ft Carson tomorrow diagnosing my truck. If any of you have some 6.0 knowledge, feel free to come give me some input.
SOBX
Colorado Springs
Well, I got out to the shop today, but didn't get to do any work. Most of the time I spent there was waiting. Hopefully tomorrow will be more productive and I will have some results to post. I could really use some help if I have to digg into the motor.
SOBX
Colorado Springs
Just got out of church. The only problem I have is that wherever I turn the truck off at is where it is going to stay for at least a day.
Sent from my SGH-T769 using Tapatalk 2
HeavyAssault
Middle, VA
HUH???? You stated you needed help diagnosing the truck. So what is going on that gives you reason to suspect an issue is present??
SOBX
Colorado Springs
Well, it has issues if it won't start when it's warm haha. I think it's a high pressure oil issue, but I'm not sure, that's why I need to diag the truck.
SOBX
Colorado Springs
I have numbers! I could only do a computer scan, but this is what I got. I took a screen shot of every parameter the computer monitored. The only issue is that I have no clue where to start. There's tons of numbers!
SOBX
Colorado Springs
I pulled these trouble codes yesterday:
P0261
P0281
P0611
P2291
My truck has a no start while hot condition. The FICM was (supposedly) checked and found good, but here is the idoling voltage anyhow, V48.0. I checked the batterise and both were good. I have tons of numbers which I got from a SnapOn SOLUS Pro. I didn't get a chance to get "cold" numbers, but what I did get was at idol on a hot motor.
ICP Data:
ICP (V) 0.86 - 0.88
ICP DSD (KPa) 4000
ICP PRESS (KPa) 4023
IPR Data:
INJ_PRS_REG (%) 25
FICM Data:
FICMLPWR (V) 13.0
FICMMPWR (V) 46.5
FICMSYNC YES
FICMVPWR (V) 13.0
I have a mountain more data!
CCRICE
Selah, WA/ Havre de Grace, MD
Looks right to me, you would probably be better off posting everything you have. And what you have with the hot motor should be fine because thats when you are having the problem.
SOBX
Colorado Springs
That'll be a lot of typing. I saved time by taking pictures of the screen and I have about 30 pictures! I'm not sure what values to post to be honest.
SOBX
Colorado Springs
Before I get off to pt, let me ask this question. Does anyone know what those codes trouble mean?
