fuel bowl O-ring replacement
n54power
This past weekend in developed a fuel leak at the fuel bowl. I tightened up the 2 brass fittings on the passenger side of the housing.
I'm considering doiNg a full o-ring replacement. Given I have two extra bowls off the truck would it be worth rebuilding one and swapping it out or are there main orings I should just replace. Kinda like if it's not broke don't fix it
suprdzlduty
Prospect, Oh
you can get those fuel line orings at John Deere too.
Part #'s are
supply is R67092
return is R74012
lines to head are R51936
