I just recently changed my fuel filter on my 2000 7.3.. I bought an aftermarket(autozone) fuel filter with cap because the cap I had on the truck when I bought it was pretty chewed up.. first time I tried priming the system I couldn't get any fuel to the bowl.. so I read that sometimes you have to pressurize the fuel tank with air to force fuel up to pump.. did that and found out I had a huge leak between the fuel bowl and the new filter head.. tightened it down and no more leak. But now it takes several (8+) key cycles to start the truck anymore.. I changed out the drain with a factory one because it was leaking fuel down the center of the block. I haven't seen nor can I find any leaks anywhere else though.. any ideas? I've read several threads on this but they all seem to peter out and don't give any definitive answers.. im aware of the hutch and harpoon mod and have not done either.. im thinking my problem lies in the fuel bowl somewhere because that's they only thing I've touched. but wanted to see if I can get any insight on the issue before I start throwing money at it. before the fuel filter change the truck would fire up in a heartbeat. after weeks of sitting and it didn't matter where the fuel level was in the tank.. when I bought the truck the fuel light was on and it still fired right up, on level surface or in my driveway on a slant it didn't matter..
