Juvenile9
I'm having a issue with high fuel pressure. My pressure sensor went bad so I replaced it and found my fuel pressure to be 100 psi. I ordered a FPR kit from Diesel O-Rings with the spring kit. Installed the gold spring and psi dropped to 80. Took the gold spring out and installed the stock spring and it dropped 76 psi. I blew air through the return line and can here bubbles in the tank. Doesn't seem like there is a restriction in the return line. Just looking for some ideas to try and figure this out. Fuel system is all stock.
