IdahoF350
So I'm pondering some low buck mods with things I now have laying around. Thing is, I recently acquired a later 2005 6.0 38 gal. fuel tank. My truck is a long bed, so the 38 gal. tank is a direct swap, and I got the plastic heat shield, the tank straps, and the skid plate from the donor truck.
I can do the harpoon mod to the tank, easy. The fuel level sender is the same range and connector even, and there is no mixer in the 6.0 fuel sender assembly. You don't exactly here about problems with air in the fuel lines on 6.0s, it was never a problem with mine anyway. If I use the later sender, I avoid the need for any internal tank mods that the hutch mod deals with.
So can I just replace the o-rings in the fuel line connectors and avoid the rubber hose? I know the Hutch mod deals with adding an in-line pre-pump filter, and I can figure something out there, but I'm not big on having endless feet of rubber hose in place of hard line, especially when I have access to the OE adapters to utilize the stock lines or minimal lengths of rubber hose.
Thoughts?
Thoughts?
