Non - Specific
Grinding Noise
[QUOTE="David N, post: 30675, member: 70"] I was gonna add that too. Depending on how long it you rode it with the needle bearing messed up... yes you may have to replace the shaft too. And fwiw, I never had any luck replacing just the needle bearing. I did it on one side the first time, and it went out in 1,000 miles. I then replaced the whole bearing assembly and the half shaft. If you do have to replace the halfshaft, you DONT have to the buy the whole assembly from Ford like they will tell you. You can buy just the outer piece that rides in the bearing. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Derkperk
Non - Specific
Grinding Noise
