Derek@Vision Diesel
Okay guys... Took the cab up about 4in to give my big hands some more room to work on a stud/delete job for a customers truck.
I have fought it long enough that maybe someone has a solution.
I put the cab back down and finished hook thing things up, went to hook the batteries up and after doing so i was crawling around in the engine bay and suddenly the horn honked twice (ground issue or pinched wire was my first thought). Could not find ANYTHING that looked to be an issue.
My buddy went and opened to door and when he did that the horn went crazy, lights started flashing (cab lights and markers, no headlights). Only way to make it quit is to unplug batteries. I checked my cab to chassis ground, both battery grounds, the cab to motor ground.
Give me something else to check, cant see any pinched wires either.
