Gutted cab
Magnum PD
VA
What would be needed if I turn my interior cab fire into a gutted essential only wiring. Just use it as a pulling truck. Used the truck for something else
Magnum PD
VA
No…..I’m ……doesn’t.
In the field running equipment, type out something on the phone and see it wasn’t right
I had a cab fire that melted the dash. Truck just sits. If I forget, climate controls, radio, maybe lights. Could mount another dash and just use rpm, OBD2 port, ignition, pedals how hard would that be?
BrewTown
Oak Creek, WI
I think No Spark Innovations? is starting to make stand alone harnesses. Although I think he needs you to send him a harness for him to modify. Saw it on the old IG. Never inquired.
And @Magnum PD I think autocorrect may have bit you in your signature. Unless your HGs really are only for show? Impressive list, prior to fire.
