Power Strokes
6.4 Aftermarket
H&S Factory pyro issue
[QUOTE="Dieselfever, post: 1014669, member: 171"] I have a truck that I just did new lifters on, put it back together and everything is fine EXCEPT the reading for Pyro1 only reads 92 degrees all the time. Before doing the work it was working correctly. I have checked the user settings in the Mini maxx and it is set to use the factory pyro. I checked both pins to the Lambda sensor(in the pass uppipe) and I have 5v reference to the one and the other has ~30 ohms resistance to ground, so my wiring has continuity I have a new sensor from Ford and it reads the same on the Mini Maxx when it is plugged in, and at 65 degrees ambient temp it has ~5.96M ohms resistance through it. The engine was pulled out to do the work and the wiring harness stayed on until I had it out and it put it back on before reinstalling it. I don't have ANY diagnostic codes and using AutoEnginuity I can't seem to find a PID for either the temp or the voltage of the sensor Any ideas on what is going on? [/QUOTE]
B
7.3 lift
Latest: Bmcgarvie
Today at 11:48 AM
7.3 Aftermarket
6.4L Ring End Gap
Latest: ncollins64
Thursday at 7:02 PM
6.4 Aftermarket
7.3 fan clutch noise
Latest: OBS-Addiction97
Thursday at 5:01 AM
6.0 Aftermarket
6
Why do 6.4 rocker arms wear out and 6.0s dont?
Latest: 6.0FinnaBlow
Wednesday at 9:00 PM
6.4 Tech
T
Mini Max Tuning
Latest: tom6mn
Wednesday at 4:23 PM
6.7 Tuning
Power Strokes
6.4 Aftermarket
