Hard start and entire driver bank going dead!
AZ Blacksmoke
Waddell, AZ
My father in law has an early 04 and at start up its hard starting, then when truck comes to temp he says the whole driver bank of injectors goes dead. He said he checked the FICM voltage and it tested good. What else could be causing the issue? Any help is much appreciated!
webb06
Seneca, MO
So on cold start all injectors are operating fine? Then when it warms up the drivers side lays out? How about a hot start? What happens then?
webb06
Seneca, MO
How does he know its the drivers side that's "shutting off"? It almost sounds like one of the FICM plugs has unplugged itself from the back of the FICM. So it's only running on 4 cylinders
Houston, TX
I've had where an injector areates the fuel, and kills the whole bank. If you remove the fuel filter cap it would let out a while bunch of air. Then it would start right up. But we would follow it on the ids, and you could see one injector dropping.. Then the others followed until the whole bank would shut the truck off. Best thing to do, replace that bank, have done a bunch where I replace one.. Then the other three start doing the same thing. Just some info and experience from our end bud. Good luck. Check fuel pressure.
webb06
Seneca, MO
That's interesting. Good stuff to know
Mdub707
Mohawk NY
If a FICM plug was loose it wouldn't be one bank either. One of the FICM plugs runs injectors 2,3,5 and 8, the other plug runs 1,4,6,7. Typically anyways... but I've seen crazier stuff happen.
The injector theory sounds completely plausible though.
Big Angry Hillbilly
Easy bubble test, tells you if you have to into isolating the banks:
Pull the secondary filter, and crank the engine over using the wire under the hood with the key off. If you've got bubbles in there, then unhook each fuel line and put a finger cut off a rubber glove over the end, and put a tie wrap around it. Crank it again and see if the glove inflates.
If you have compression gas in the fuel rail:
Typically this necessitates replacement of the entire bank of injectors, and thorough inspection of the cups to make sure there's no damage (especially if you find a burnt copper washer) replacement of the check valve in the head, as well as verifying base fuel pressure as this can lead to injector failure/harmonics that cause the injector to bust itself apart and cause this occasionally.
