MrOneEyedBoh
- Joined
- Feb 24, 2013
- Messages
- 799
- Reaction score
- 0
Okay here is a run down. I bought the truck with 36k on it in Feb this year. Fast forward to early November this year. I installed the Edge Fuel pressure sender and FORD blue spring at the same time. I never checked stock fuel psi.
The fuel psi with the FORD blue spring was 59-60 idle and 51-52 WOT. The first weird thing was the PSI would get a FAST intermittent drop to 34-35 during WOT runs. So I thought maybe the HFCM was going bad ( due to the intermittent drop during WOT runs and lower than usual PSI's with the FORD blue spring ). So then I replaced it with a new HFCM today ( OEM ) . I primed it, got the air out etc etc. Still the same pressures as before, but NO drop during the WOT runs. Now the pressures are 60.5-ish idle and 52.3 at WOT sustained.
So I had a brand new International spring kit here and installed that to maybe bump up the idle psi. I thought there could have been a bad spring in the package or whatever. I installed the International spring and it bumped the damn idle to 100 psi. W T F..
So I then went back to the Blue FORD spring and its at 60ish again at idle.
Does anyone know WTF is up? Anyone on here have an Edge CTS with the ISSPRO fuel sender ( came with my Edge kit ) and is willing to try this International spring to see what their idle gets to?
