speedracer1000
got a 04 6.0 with high miles that i just did hg's studs, egr delete, the whole 9 yards. never drove the truck before we did the work my buddy bought it and i just towed it to the shop, had a blown oil cooler didnt wanna drive it too much. anyways i did all the work got it runnin took it for a ride, has no power under load and coughs back through the intake like its over boosting, which it is, has plenty of boost but i keep getting a code for turbocharger underboost and exhaust pressure sensor. so i try loading a steet strategy tune to see if it changes anything, and it doesnt, so i check the usual connections, maf, ebp, vgt, ect. but i notice that when i first started the truck i could hear the vgt cycling and now i cant, it just doesnt sound right while driving, also i have a snap on modis scan tool, and i can command vgt duty cycle from 0-85% and when i do that none of the values, ebp, map, ect doesnt change. so at this point it looks the turbo is sticking. but if so y no power? its got all kinds of boost so you would think it would have plenty of power still, so does the pcm defuel in the event the turbo vgt doesnt work?
